Canon Dadf-h1 separation issues
  • Canon.Tech
    replied
    Re: Canon Dadf-h1 separation issues
    Yes I have seen the separation start to fail on this DF even with a new pad etc. I have replaced a few of these clutch springs but it doesn't seem to make any difference in the separation, after all that clutch only controls the pick-up & feed nothing to do with separation? Shame as this machine is very reliable, not even as good as the 2270/3225 etc
  • blazebusiness
    replied
    They're not much fun to get to. It's going to add time to your rebuilds. =^..^=
    Yeah, but not much choice my friend. Now that those feeders are getting older it's going to be a required item. That machine sure is a great box. Still a lot of them out there even after all these years. After doing a couple of those one way pulleys my speed will greatly improve on installing that part. Thanks again for the responses. You guys are great.
    replied
  • blazebusiness
    replied
    Originally posted by teckat
    JAM CODES ?????????????
    Inspect & or > Replace the one-way pulley ( FB5-9466-000 )
    No---no jam codes.....just a general question. I'll start replacing those one way pulleys then as part of the normal AF rebuild. Thanks for getting back to me.
    replied
    Originally posted by blazebusiness
    The doc feeder for the IR3300 series are quite a bit older now and I'm noticing at this age level , that they like to feed multiple sheets even after you replace the PU roller , Feed/Sep roller and the 2 sep pad assemblies. Any ideas as to what works for you to resolve this much appreciated-Blaze
  • blazebusiness
    started a topic Canon Dadf-h1 separation issues
