irc3080
  • steve schofield
    • May 2010
    • 117
    irc3080
    Have a irc3080 where user cannot adjust light/darkness from screen ..everything else working fine ..any ideas??
  • canonbundy
    • Jun 2012
    • 607
    Re: irc3080
    Assuming the User knows where the Display adjust is on the Control Panel, I would say the Inverter is not working to light the LCD (pink & white wires on PCB inside Control Panel).
    • teckat
      • 16083
      Re: irc3080
      11= Display Contrast Dial
      Use to adjust the brightness of the touch panel display.
      Lightness / Darkness of what ??
      Panel or Document
      • steve schofield
        • May 2010
        • 117
        Re: irc3080
        thx for reply,,,,i have swopped whole control assembly as user has many same machines on site...but no change any more thoughts??
        • steve schofield
          • May 2010
          • 117
          Re: irc3080
          sorry...not contrast of screen....the touch screen button to lighten /darken copys..
          • teckat
            • 16083
            Re: irc3080
            check under Additional Functions>
            - under Adjustment/Cleaning>Exposure Recalibration>Light, Dark: 1 to 9 levels> make sure it is set at "5"
            or could be a Main Controller issue
            • steve schofield
              • May 2010
              • 117
              Re: irc3080
              thx for reply...will see machine tomorrow....main controller is what im thinking....expensive fix !!
              • canonbundy
                • Jun 2012
                • 607
                Re: irc3080
                Is the problem from copying or printing or both?
                Try an internal print, say FUNCTION > MISCP > USER PRINT - if the print is ok then copy the print, if the result is lighter then maybe the Optics need cleaning .
                • Canuck
                  Tech Specialist
                  • 1713
                  Re: irc3080
                  Try to reprogram screen in service mode. If no success replace the touch screen sheet. There is a Canon bulletin about this issue. Have changed quite a few on all Canon products. FK2-0426 is part number for 3080. Do the firmware first
                  • teckat
                    • 16083
                    Re: irc3080
                    note------------------
                    poster quoted below
                    • Canuck
                      Tech Specialist
                      • 1713
                      Re: irc3080
                      poster quoted below
                      whoops...didnt see that
                      • steve schofield
                        • May 2010
                        • 117
                        Re: irc3080
                        it was main controller....!!!!!!
