IR 2200 Error 602-000-3
  • mido
    • Nov 2011
    • 176
    Hi all,
    I have a problem in IR 2200, it shows E602-000-3,
    and please can you tell what this error means is?
    Regards
  • teckat
    • 16092
    Re: IR 2200 Error 602-000-3
    Originally posted by mido
    Hi all,
    Regards
    E602 is generally an error with the Hard DIsk Drive (HDD) in the imageRUNNER. It can also be a problem in the controller board to which the HDD connects.
    HDD could be toast & u need to replace it > u then need to format it & re-load firmware with SST program
    try this first-u may get lucky
    defrag HDD
    hold down the '1' and '9' keys on the keypad for approximately 6-8 seconds. A flashing block will show in the top left corner of the LCD. Normally, 'HD-Check' lasts about 15-20 minutes, and ends if no fault is encountered or specific sectors have automatically been repaired bringing up DOWNLOAD MODE on the LCD. DO NOT STOP ONCE STARTED.
    In certain cases,"HD-Check" can take longer than 15-20 minutes and sometimes the machine can hang in this mode and will never complete.
