ir3300 boot rom
  • ymmtech
    replied
    Re: ir3300 boot rom
    Its posibble to flash a "C" to "N" on the fly without removing screw.
  • copicatt
    replied
    Re: ir3300 boot rom
    Originally posted by Klydon
    There is a further issue beyond just switching Boot Rom's on these machines to make them work one way or the other. Each has its own system software and you need the correct system software loaded along with the correct boot rom to make the machine
    operational.
    Yes, I'm aware. I have flashed these many times, but I just wasn't for sure the one bootrom I had was the "N" version. Either way, ended up not having to install. Customer has two of these and only one had print. They wanted both to print because they were going to do a print job. I then found out it was 130,000 prints. They have decided to outsource, thank goodness. I've had these models doing 25k per month, but not 70k in two weeks. lol
  • Klydon
    replied
    Re: ir3300 boot rom
    There is a further issue beyond just switching Boot Rom's on these machines to make them work one way or the other. Each has its own system software and you need the correct system software loaded along with the correct boot rom to make the machine operational.
    replied
    Re: ir3300 boot rom
    Originally posted by copicatt
    can someone tell me if this is the N boot rom or C boot rom that I have...i have the NIC, but not for sure if this is the correct bootrom.....
    The # on the sticker is FG3-1750 ver 07.25
    I have a customer that is needing print for just a while as they do a pretty large job and had these lying around....
    thanks for any input!
    imageRUNNER 2200/ 2800/ 3300
    FG3-1743-000 is a C Boot Rom
    FG3-1750-000 is a N Boot Rom / I believe
  • copicatt
    replied
    Re: ir3300 boot rom
    i don't actually have a machine in shop....just had these lying around....i may just have to give it a shot. was just wondering about the bootrom mainly...hopefully it is the correct one. thanks for your reply.
  • Canuck
    replied
    Re: ir3300 boot rom
    Go into service mode,DISPLAY/VERSION...look for the boot...it will have an N or a C. 3320 has meap. Completely different firmware. You need 3300N firmware
  • copicatt
    replied
    Re: ir3300 boot rom
    also I have a hard drive pulled from a 3320i that is working. is this the same software as the 3300N? if so, I am just going to swap the drive.
  • copicatt
    started a topic ir3300 boot rom
    ir3300 boot rom
