Canon İR 105+ help me pls
  • funnestfan
    • Feb 2013
    • 7
    We have canon ir 105 + machine. Machine give error E000051-0002 code. İs this error code electrical? Where are the problems in machine?
    first machine gives paper jammed error. we are doing dublex unit replace than same error code. Thanks for patiance.
  • Luther
    • May 2006
    • 682
    Re: Canon İR 105+ help me pls
    E051
    Main cause The horizontal registration sensor (PS18) is faulty. The horizontal registration
    motor (M15) is faulty. The DC controller PCB is faulty.
    Condition
    0001 Departure from home position is not detected within 5 sec during a
    horizontal registration home position search.
    0002 Home position is not detected within 5 sec during a horizontal registration
    0003 The horizontal registration detection movement for the preceding
    sheet does not end within 5 sec at the start of a horizontal registration
    • canonbundy
      • Jun 2012
      • 607
      Check for a small pice of paper in the machine frame Duplex Connector - also the Connector of the Duplex Unit - happens.
