Canon ir 7095 Finisher giving Error code 5F0-8002 ?
8001 = fault in stopper HP sensor or stopper motor The stopper HP sensor does not go on within 5 sec after the start of the
stopper motor.
- Check the connectors of the stopper motor and the stopper HP sensor.
- Replace the stopper motor and the stopper HP sensor.
- Replace the saddle stitcher controller PCB.
8002 = fault in stopper HP sensor or stopper motor The stopper HP sensor does not go off within 5 sec after the start of the
stopper motor.
PS107--saddle lead edge stopper HP sensor M105 -- saddle lead edge stopper motor
stopper motor.
stopper motor.
Thanks Teckat,
in between may i noe where is the Stopper motor And stopper HP sensor??
Re: Canon ir 7095 Finisher giving Error code 5F0-8002 ?
Originally posted by Pv6 Copier
Thanks Teckat,
in the Saddle Stitcher Unit)
tack off back cover of Finisher> then look all the way on bottom> motor105 lower right/sensor PS17 lower bottom left
service mode to test the Finisher-V2 M105 Saddle Lead Edge Stopper Motor?
--Use the following procedure to rotate the M105 saddle lead edge stopper motor and move the edge stopper assembly.
Note: The front door interlock must be actuated for this test mode to work.
1) Power off the finisher
2) Place the DIP switch SW382 to these settings
3) Power on the finisher (Note: To test the finisher it is not necessary to power on the copier)
4) Press switch SW385 to enter the service mode
5) Press switch SW383 to lower the edge stopper
6) Press switch SW384 to lift the edge stopper
7) Press switch SW385 to lower the edge stopper and exit service mode
8) Power off the finisher and reset DIP switch SW382 to the original setting
