Canon İR3025 Error Help me
  • funnestfan
    • Feb 2013
    • 7
    Hello friends. I have Canon ir 3025 photocopy machine. Machine gives Error E 000110 0001 code. What is this ? How is it repair ?
    Thanks..
  • teckat
    • 16083
    Re: Canon İR3025 Error Help me
    Thanks..
    e110-0001
    The scanner motor is faulty.
    The scanner motor speed lock signal does not indicate a locked state a specific period of time after the scanner motor has been started.
    even though it points to Scanner/ this code is difficult to pinpoint in this series
    1-? does the printer come to ready>then code pops up
    2-? were u working on printer before code issue
    3-? is the code intermittent/ or constant on power on
    4- ? does code pop up after running copies
    https://learn.sparkfun.com/tutorials/how-to-use-a-multimeter/all
    do a continuity check on all Fuses /on DCpcb.
    see example below------------
    also check the Leaf spring on the front side of the machine for the steel registration roller.
    The spring must be making contact with the roller. Please see the photo below.
    • Field Man
      • Sep 2015
      • 7
      thanks it work for me the fuse had cut off
