how can i change the language of ir 3300??
  • eng_migo
    • Jun 2008
    • 16
    hi
    plz i wanna know
    how can i change the language of ir3300??
    • 23008
    Enter service mode, *, 2 & 8 together, *,
    COPIER, DISPLAY, USER, LANGUAGE (displays <LANGUAGE xxyy.zz.aa>),
    xx = country code
    yy = language code
    zz = destination code (i.e. Canon)
    aa = paper size configuration code (00: AB, 01: Inch, 02: A, 03: all sizes)
    Sorry, my handbook does not offer the possible settings.
    From another part of the manual I found this. You can try:
    EN English
    FR French
    ED German
    IT Italian
    JP Japanese
    CS Czech
    DA Danish
    EL Greek
    ES Spanish
    ET Estonian
    FI Finnish
    HU Hungarian
    KO Korean
    NL Dutch
    NO Norwegian
    PL Polish
    PT Portuguese
    RU Russian
    SL Slovenian
    SV Swedish
    TW Chinese (traditional)
    ZH Chinese (simplified)
    You can confirm your setting at: COPIER, DISPLAY, VERSION, LANG-xx
    I''ve only changed language on a machine once. It was a Mita-5585, and I thought it would be cool if the display was in Japanese. You know, mess with the salesman... Well, I didn't take one thing into account. I cannot read Japanese, so I couldn't put it back. Not without a scolding, and key by key instructions from Mita in Chicago.
    • panalkar
      • Jul 2005
      • 43
      eng migo,
      If you dont find language what you need ,then you need to use SST & download appropriate languange to copier.
      • alex@wocltd.com
        • 430
        what langauge do you want?
        • eng_migo
          • Jun 2008
          • 16
          Originally posted by panalkar
          eng migo,
          from where i can get the SST?
          • eng_migo
            • Jun 2008
            • 16
            i wanna English language plz
            • panalkar
              • Jul 2005
              • 43
              You need to have SST & System software which will be available with Canon authorised Agent in your area. You need to call their service engineer.
              • alex@wocltd.com
                • 430
                if you clear everything - I mean everything the majority of kit will revert to english
