ir7105- S1 Fiery
  • aco.bk
    • Sep 2012
    • 130
    ir7105- S1 Fiery
    Is it possible to reinstall OS on fiery S1?
  • Alex ahir
    • May 2012
    • 125
    Re: ir7105- S1 Fiery
    yes, you need sys. software
      • 16083
      [[[[[[[[[[[[;System software installation takes approximately 10 minutes (not including the time required to configure Setup)
      Print the following from the Functions menu (if possible):Configuration pageont Lists-Insert the system software CD into the CD-ROM drive.
      NOTE: If you installed a new HDD, turn on the system using the power switch on the back panel, insert the system software CD in the CD-ROM drive, allow the system to boot--------
      -Select Shut Down from the Functions menu--
      -At the next screen, select Reboot System.
      Allow the system to shut down and reboot. Routine start up diagnostics display on the Control Panel as the system reboots.
      When the following screen displays, select YES to install system software.
      The installation process begins immediately. The following status messages display on the Control Panel:
      NOTE: The list below is approximate. The actual list you observe may differ slightly.Do not push any buttons during this time and ignore the message>Press any button to enter config mode that appears on the Control Panel while the system reboots.
      When the Select Language screen displays, scroll to the appropriate language, and then select OK.<-->Press the 4th line selection button
      When the Select Market Region screen displays, scroll to the appropriate region, and then select OK.
      Wait as messages display indicating that the system is restarting and then re-establishing communication with the copier.
      -When prompted to enter a password, enter Fiery.1 using the Up and Down buttons on the Control Panel -
      NOTE: Enter Fiery.1 exactly. The password is case-sensitive; for example, fiery.1 will not work.
      -Select OK.
      -When the Setup Menu displays, configure Setup using the Configuration page you printed earlier.
      -Bypass any settings that are not included on the Configuration page if it is more appropriate for the network administrator to set them. For more information, see Configuration and Setup on the User Documentation CD.
      -Re-install fonts, user software, or custom simulations that may have been deleted when you installed system software.
      NOTE:
      • aco.bk
        • Sep 2012
        • 130
        How to obtain SYS cd?
          • 16083
          imagePass S1
          Canon Sales
          FE1-6065-000/ SYSTEM SOFTWARE
          FE1-6062-000/ MEDIA PAK
          Or>Online
          FY9-5101-000/ imagePass S1 SYSTEM and User Software v2.1= $40.00/$50.00
