IRADC9280/C9270/C7270/C7260+G ver./ E020-0081
    • 16083
    [Error Code] IRADC9280/C9270/C7270/C7260+G ver./ E020-0081
    Minimizing E020-0081 Error Codes
    Publication describes an occurrence of error code E020-0081 due to a faulty shutter link (FC8-1775-000) on the Patch Image Read Sensor Assembly.
    On the Patch Image Read Sensor Assembly, the shutter link contains bosses which ensure the proper position of the shutters. The above Serial Numbers affected may have a shutter link with a boss slightly shorter than the other bosses [a]. This may cause the shutter to be out of position [B]thereby creating an E020-0081 error code.
    see pdfs.---
    E020-0081 due to a faulty shutter link on the Patch Image Read Sensor Assembly.pdf
    Shutter Link Replacement Procedure.pdf
    Products Affected
    : ////////////////Serial Numbers Affected:
    imageRUNNER ADVANCE C9280 ---LVD00701 ~ LVD00907
    imageRUNNER ADVANCE C9280G --LVE00517 ~ LVE00519
    imageRUNNER ADVANCE C9270 --LVM00644 ~ LVM00821
    imageRUNNER ADVANCE C9270G --LVN00509 ~ LVN00519
    imageRUNNER ADVANCE C7270 --LVX01219 ~ LVX01876
    imageRUNNER ADVANCE C7270G --LVY00542 ~ LVY00545
    imageRUNNER ADVANCE C7260 --LWA01375 ~ LWA02469
    imageRUNNER ADVANCE C7260G --LWB00543 ~ LWB00571
