blue bar in print (w8400)
  • ninjai
    • 13
    i've just changed my head (1 month )
    but in some work i see these blue or purple bar in print.
    whats wrong ? !
  • V-P
    • Apr 2011
    • 679
    Re: blue bar in print (w8400)
    perhaps you are using non oem inks ?
    • ninjai
      • 13
      the ink is the same as ink i use from 3 months ago
      • V-P
        • Apr 2011
        • 679
        my question was different
        • ninjai
          • 13
          if its not oem why its work good this long time?
          can it be from bubble in tube ? i see some bubble in some tube of my plotter
          • V-P
            • Apr 2011
            • 679
            Using non oem ink will cause premature print head failure and other symptoms (in most cases).
            Unless you are really practical in lfp-s I would stay away from it.
            Non oem ink has different chemical attributes than oem ink.
            • ninjai
              • 13
              any other idea???
              my ink tanks are old . can it cause pumping bubble in tube when ink is being pumped ?
              • V-P
                • Apr 2011
                • 679
                try cleaning head B a couple of times and see if the air bubbles are gone.
                • ninjai
                  • 13
                  doesnt it hurt the head ?!
                  • V-P
                    • Apr 2011
                    • 679
                    lol - No it does not
