ir 3170f
  • opensourcetz
    [Error Code] ir 3170f
    e000006-0000 canon ir 3170f
    • 8144
    Re: ir 3170f
    There is no such error as this, double check your code
    • northernlife
      • Sep 2011
      • 847
      Re: ir 3170f
      Yes it is an error code on the 3100's. How old's your manual?
      E006 Connection error of the fixing unit
      0000 The hardware detects non-attachment of
      the fixing unit for 400msec
      continuously.
      A break in the fixing unit presence/
      absence signal (FUSER_CNCTX_N) /
      Disconnection of the connector (The
      connectors are placed as shown below)
      DC controller PCB : J316
      Fixing unit : J2007, J2008
      Relay connector (between DC
      controller and fixing unit) : J2006 (7
      pins)
      Check on connection of the fixing unit cable,
      Replace the relay cable, Replace the fixing unit,
      Replace the DC controller PCB
        • 8144
        Re: ir 3170f
        I stand corrected, i've not seen one of those old 3100's toner spitting boxes in a while!
        • northernlife
          • Sep 2011
          • 847
          Re: ir 3170f
          Hahaha the biggest piece of shit colour that canon ever released. So bad we had to pull one of the machines and replace it with a 3380 because it was chewing that much parts, and the unit was 4 months old.
          • Canuck
            Tech Specialist
            • 1713
            Re: ir 3170f
            Personally I think the 6800 is shittier that the 3100...heat adding/removing roller....good for making square fuser rolls,ASI drum for color(horrible for color). The Edsel of Canon color
