Change new hdd. Then up e602-002
  • freefly
    • Jan 2013
    • 20
    Change new hdd. Then up e602-002 ir7095
  • mramlawi
    • Jul 2011
    • 838
    Re: Change new hdd. Then up e602-002
    Did you install the system software on it !!?
    Distinguished road makes you jewel in rough
    • teckat
      • 16084
      do u have Models Firmware loaded into SST ?
      1-PRINTER Model ?
      2-is HDD the correct one for your model ?
      3-did u first format new HDD using SST Program
      4-Are u a trained tech
      • MFPTech
        • 486
        Originally posted by teckat
        no mind readers here[ATTACH=CONFIG]26025[/ATTACH]
        1-PRINTER Model ?
        You do not need SST to install a HDD
        • teckat
          • 16084
          How do u then format the NEW HDD with the HDFormat.ift file/ then load printer firmware
          if your talking about cloning/ take it somewhere else
          • laitang
            • Nov 2012
            • 627
            After Replacing the Hard Disk:
            1) Formatting the HDD:
            Start up the machine in safe mode (i.e., turn on the main power while holding down the 2 and 8 keys).
            Using the HD formatting function of the SST, execute full partition formatting.
            2) Downloading the System Software:
            Using the SST, download the following: System, LANG, RUI, PS-FONT, OCR dictionary, SSL encryption key, SSL CA certificate, MEAP content.
            3) Execute the following service mode item:
            COPIER > FUNCTION > CLEAR > CA-KEY (Level 2)
            4) Turn off and then on the power.
            • teckat
              • 16084
              already know that/
              other poster said otherwise
              • spectraindo
                • May 2008
                • 313
                Replacing the Hard Disk on IR7095 is not as easy as 123.
                First you must know the version of the Bootrom is it V-1 or V-2, then choose the right System Software.
                You can find it on a previously printed P-PRINT.
                Register the System software in the SST and Download to the machine.
