Change new hdd. Then up e602-002
  • spectraindo
    replied
    Re: Change new hdd. Then up e602-002
    Replacing the Hard Disk on IR7095 is not as easy as 123.
    First you must know the version of the Bootrom is it V-1 or V-2, then choose the right System Software.
    You can find it on a previously printed P-PRINT.
    Register the System software in the SST and Download to the machine.
    replied
    Originally posted by laitang
    After Replacing the Hard Disk:
    1) Formatting the HDD:
    Start up the machine in safe mode (i.e., turn on the main power while holding down the 2 and 8 keys).
    Using the HD formatting function of the SST, execute full partition formatting.
    2) Downloading the System Software:
    Using the SST, download the following: System, LANG, RUI, PS-FONT, OCR dictionary, SSL encryption key, SSL CA certificate, MEAP content.
    3) Execute the following service mode item:
    COPIER > FUNCTION > CLEAR > CA-KEY (Level 2)
    4) Turn off and then on the power.
    already know that/
    other poster said otherwise
  • laitang
    replied
    replied
    Originally posted by MFPTech
    You do not need SST to install a HDD
    How do u then format the NEW HDD with the HDFormat.ift file/ then load printer firmware
    if your talking about cloning/ take it somewhere else
  • MFPTech
    replied
    Originally posted by teckat
    no mind readers here[ATTACH=CONFIG]26025[/ATTACH]
    do u have Models Firmware loaded into SST ?
    1-PRINTER Model ?
    2-is HDD the correct one for your model ?
    3-did u first format new HDD using SST Program
    4-Are u a trained tech
    replied
    Originally posted by freefly
    Change new hdd. Then up e602-002 ir7095
    1-PRINTER Model ?
  • mramlawi
    replied
    Did you install the system software on it !!?
  • freefly
    started a topic Change new hdd. Then up e602-002
