Re: Canon 5185 can't find H1 server after replacing server
Try switching the hard drives between units, after marking them first
you may get lucky
hi,
i dont have an update cd. i paid 150 for it. I know they are a lot more new.
i wish it would work.Leave a comment:
Hi, thanks for the reply.
According to the printout that came with the server it says Software: EFI Fiery system 8e Version: 1.02
I am not sure where to find the software on the printer, but the system report says MEAP Contents: 88.02 is that my version?
I tried those steps because I saw them on one of your other posts. I tried them again and it made no difference. Could it be my software versions? can I update the software?
Printer firmware is good,
Did u receive firmware disks for H1_?
Buyer beware on eBay purchase of hardware.
How much did u pay for it_?
That H1 is an expensive item.Leave a comment:
I tried those steps because I saw them on one of your other posts. I tried them again and it made no difference. Could it be my software versions? can I update the software?Last edited by crwoo; 11-28-2014, 10:01 PM.Leave a comment:
Hi, I have a C5185 with H1 controller that i would like to throw off the server, but as I hear that isn't easy.
My problem is that my H1 server required rebooting a few times a week to work so I bought one off ebay that is guarenteed working, I have the reports from it. Problem is when I install it on my prnter, the printer doesnt find it. When I go to that tab it says if it doesn't show up in a moment I should check power.
I have tried changing the COPIER>OPTION>INTFACE>IMG-CONT to '0' and back to 3 and it didnt help. the server shows 00 so I assume it's booted and ready to go. I have double checked to make sure it's plugged in. is there anything else I have to do when replacing the H1 server or an easy way to remove it and print with UFRII?
Your help will be appreciated.
if this is an imagePASS-H1 v2.0 > iRC5158 needs to be v78.01 or newer before connection ????
re-establish the install procedure--
Complete Re-Install of the H1 > just as if u were first doing a set up.
First-Remove all connections cables(I/F Communications Cable,Cross Ethernet Cable, & Network Cable from H1 to Copier/also unplug H1 power cord.
*NEXT>>>>follow below EXACTLY AS SHOWN
1. Enter Service mode (Additional Functions > 2 and 8 > Additional Functions).
2. Select Copier > Option > Int-Face > IMG-CONT.
3. Change the setting of IMG-CONT back to "0"
4. Hit OK and (& follow the normal shutdown procedure of Printer) then Re-Boot the Copier.
5. Re-Enter Service mode (Additional Functions > 2 and 8 > Additional Functions).
6. Change the setting of IMG-CONT back to "3"
7. Hit OK and ( again >follow the Normal Shutdown Procedure of Printer)
8. With Printer "OFF", u now Connect all of the 3 Cables that were previously removed.>don't forget H1 POWER CORD--
9. Now > Power back up Printer
10. At the Control Panel, press [Printer] tab.
11. Press [Printer Status/Settings].
12. At the Languages Setup screen, select the name of the language you want to use, and then select OK.
Wait a few minutes.
13. Input of password Fiery .1
14. In response, the machine will automatically show the Settings menu.
15. Be sure to at least select the following and make the appropriate settings in the indicated order:
[Server Setup], [Network Setup], and [Printer Setup].
Checking the Operation After Making the Settings
Print out a test page and a settings page as follows to make sure that all settings have correctly been made on
the machine and its host machine and that all connections are normal------
1) Press (=>) displayed at upper right on the LCD of the connecting device.
2) At the Control Panel, press [Print].
3) Press [Printer Status/Settings].
4) Make the following selections on the LCD:function>print page>test page/configuration.
Hopefully this Procedure will get u up and Running/Works about 90% of the timeLeave a comment:
Tags: None
