canon ir 7095
  • Saji
    • May 2010
    • 97
    canon ir 7095
    Canon ir 7095 is showing E 840-000, checked the fixing inlet sensor, motor, swapped the fixing unit, replaced the Dc board, checked the connectors etc, problem still persists. when i keep front door open machine gives E -111, E 25-001 etc,what could be the problem, please help, thanks in advance.
  • Jhonjon
    • Sep 2013
    • 207
    Re: canon ir 7095
    I also encountered different error code in the same model. Error in laser unit, fuser error only to find out that the transfer unit is the one causing the errors.
    • Saji
      • May 2010
      • 97
      Re: canon ir 7095
      Sir teckat>>please give me some help to solve this problem, thank you
      • vigour
        • Aug 2010
        • 1034
        Re: canon ir 7095
        You have got a tough one there.
        Check the fuses on DC controller that you removed.
        E840 is an indicator that you have lost 24v 0r 38v, usually because of a short.
        Disconnect finisher, feeder, paper decks,
        See what happens when you leave the fixing feeder and/or duplexer out.
        Most likely a motor or fan motor is shorted.
        eg M1, M13, FIXING MOTOR
        disconnect connectors from dc controller one at a time until you get to it
        Make sure the controller is still good first.
        my e840 was caused by a shorted new fuser
        Afte rblowing a couple dc controllers I had to solder in a fuse holder and buy some fuses.
        good luck
        • SAZ911
          • Mar 2013
          • 193
          Re: canon ir 7095
          Hi,
          Can you please confirm the error codes as i have only found the e-25 in the manual, which is a toner supply issue.
          In the past when i've had random error codes come up, i found it was usually something i did ie; left a connector unplugged for a fan or motor or ...
          good luck....
          SAZ911..........
          • Saji
            • May 2010
            • 97
            Re: canon ir 7095
            i finally able to find the problem, it was in the first cassette pickup unit, i replaced the unit..now machine working well,i guess something is shorted in that unit..
            • vigour
              • Aug 2010
              • 1034
              Re: canon ir 7095
              There is usually a frayed wire on a clutch on that unit
