Canon Advance C7055 print darker after auto full gradation ????
  • digitalpressvietnam
    • Jun 2012
    • 51
    I replaced developer and drum unit from other machine. The prints become darker after auto full gradation. Please help me solve this problem
  • teckat
    • 16092
    Re: Canon Advance C7055 print darker after auto full gradation ????
    u have an external server connected ???
    proper sequence to calibrate copier and imagePASS/ colorPASS
    the sequence is to do an AUTO COLOR MISMATCH first, then a CORRECT SHADING, followed by a full AUTO GRADATION,
    then COLOR CALIBRATION for the image/color PASS. if connected
    CORRECT SHADING and COLOR CALIBRATION should be performed using a Spectrophotometer (i1 Basic Pro). if available
    Also check > primary corona assembly
    if all Fails__________last resort is
    Backing up DC-CON: (Service Mode Level 2 Copier-Function-System-DSRAM-BUP).
    Clearing DC-CON: (Service Mode Level 1 Copier -Function-Clear-DC-CON) reboot the machine.
    Restoring DC-CON: (Service Mode Level 2 Copier-Function-System-DSRAM-RES) reboot the machine.
    Run Auto Gradation Full Adjust.
      • Jun 2012
      • 51
      Thanks Mr.Teckat so much. Server ready connected. I will do as your instruction.
      • Canuck
        Tech Specialist
        • 1713
        You can't just swap devs from one machine into another on these machines. Put in a new dev and follow proper instructions(initialization,etc)
