iRA 6275 1205 1011 jams
  • MFPTech
    • 486
    Hi,
    I have two iRA 6275 machines side by side with intermittent 1205 and 1011 jams pointing to the same sensor in the finisher
    1205 OTH *PI103
    1011 Delay PI103*
    The machines are 1 year old with 1 mil clicks each.
    They are leveled.
    Have replaced the exit rollers on the machine side.
    Reseated the connector J883 on the feed drive of the Finisher.
    Any suggestions please
    Thanks in advance!
  • teckat
    • 16083
    Re: iRA 6275 1205 1011 jams
    Originally posted by MFPTech
    Hi,
    1205 OTH *PI103
    1011 Delay PI103*
    They are leveled.
    Thanks in advance!
    ???? is this when Stapling ??/ if so does Stapler move
    1205-----------------
    Check the stapler home position sensor PI110 in the copier service mode I/O (Service mode>Copier>I/O>Sorter>P017 Bit 4) and block/unblock sensor PI110. If PI110 does not change states, replace it
    1011-----------
    Check if the Connector J883 is loose on the Feed Driver > try re-seating the connection
    Connector goes to the Inlet Motor M113. The following image shows the location of the connector on the rear side of the finisher.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      Nice pic!
      • MFPTech
        • 486
        if you read my post i said i did that. Thanks for your reply anyway
        • teckat
          • 16083
          Did u check for the proper voltage supply on those connections
          also> wire ties are an ongoing issue on these IRADV/IRADVC's -- as with most Canons, especially yellow harness ones-
