Helo,
I am using a Canon C1 with ceramic toner.
I did made the Shading correction printing and measuring tests with the Xrite Eye one.
Because when I tried to measure the magenta , red strip with ceramic toner I got error , I did measure the magenta Strip printed before with normal Toner.
So I measured the Cyan, Yellow , Black Strips from the Ceramic toner Shading print and the Magenta Strip from the normal toner Strip.
I tried to measure the Magenta Ceramic toner patch densities in order to input some Visual correction to be as close possible.
I tought that measuring the densities of the ceramic C Y K , and checking the automatic correction values , I can find out what correction to input for the Magenta .
The user manual information regarding the Visual Correction are not exhaustive.
Do anyone , have more information regarding the visual Shading correction ?
Thank you
Thank you
