canon iR2545 error E000000
  • markndreu
    • Mar 2014
    • 34
    canon iR2545 error E000000 i have change the fuser unit but the same if i have clear engime is ok, but for 20minutes error E000000 again
    Please help me if you know
  • teckat
    • 16083
    Re: canon iR2545 error E000000
    E000-0000 error code===To clear a Fuser Error enter Service Mode >CLEAR>ENGIN>ERRCLR
    You must follow steps below to clear E000
    Enter service mode by pressing additional functions than 2 than 8 and then Additional Functions.
    #SSSW will be displayed.
    Use the right arrow and scroll to #CLEAR then press OK.
    Then Use the right arrow and scroll to ENGINE then press OK.
    ERRCLR will be displayed then press OK. Then power cycle the machine.
    -Your AC wall voltage was double checked and was within specifications. ??
    -Make sure there is AC voltage being output to the fixing unit on connector J110.
    Connector J110 is the AC connector which supplies AC voltage to the fixing film unit heater.
    -If not u may have a Power Supply Assembly Issue.
    Below are images that show the Power Supply Assembly location and connector J110's location.
    The machine's lower left panel needs to be removed in order to access the Power Supply Assembly.
    see back link on your other post
    http://www.copytechnet.com/forums/ca...9070pro-3.html
