c9070 it make duble color (i cant auto correct color mismatch)
  • markndreu
    • Mar 2014
    • 34
    Haw can i make (auto correct color mismatch)
    Because it cant make
    i have clear itb film but the same
    what i can make itb film ??
  • teckat
    • 16092
    Re: c9070 it make duble color (i cant auto correct color mismatch)
    ******may be caused by a faulty Patch Shutter operation.
    imageRUNNER ADVANCE C7055 / C7065 / C9065 PRO / C9075 PRO / C9065S PRO / C9075S PRO / C9280 PRO / C9270 PRO / C7270 / C7260
    Auto Correct Color Mismatch Is Failing
    Auto correct color mismatch is failing.
    When this occurs, check the alarm history (Service Mode > Copier > Display > Alarm2).
    In some cases, there were several 340004 alarm codes in history.
    This alarm pertains to the correction amount of the skew correction motor in or more of the lasers, to have exceeded the limit. In this instance, while looking at a PG6 test print, magenta had a slight skew.
    😦 Homing out the lasers in service mode didn't correct the issue (Copier>Function>Laser>LD-ADJ-Y/M/C).
    Fix was> all three color laser units were taken out of the machine and the wire ties removed to resolve the issue.
    Additionally, the connections to the laser driver were also reseated.
    Also***clearing the DC Controller, performing an ITB INIT and then performing the auto color mismatch may correct the issue.
    Note 1:😨
    Before clearing the DCON, Back up the DC CON Data by entering service mode LEVEL2> COPIER> FUNCTION> SYSTEM> DSRAMBUP> OK
    Note 2:😦
    After Clearing DCON an E991 will occur. To clear the E991, power cycle the machine and enter Service Mode LEVEL 2> COPIER> FUNCTION>SYSTEM>DSRAMRES>OK to restore the data.
    • MaksiSela
      • Apr 2017
      • 6
      20181107122254
      20181107122236
      i have this problem with my printer canon ir adv c9070pro.
      i have change about 5 yellow developing unit and drum unit.
      when i change it just print a few pages about 200 pages and goes again yellow like in document i have sent you.
      any idea why that happens
        • 22809
        Originally posted by MaksiSela
        20181107122254
        20181107122236
        AGAIN not the same ISSUE.. start your OWN thread!
        • dan7777
          • Dec 2012
          • 680
          We have had the developers cause auto correct color mismatch not to work. Get 12x18 paper and run test page 10 and if the edges of the colors are bad that is the developer to replace. The sensors are on the outer edges. We had one in a print shop that did that.
