I have a unit that will not read the right original size off the copyboard glass. The adf is fine, I've replaced the ccd, and sensore, plus the controller. Still the same result, has anyone had this issue before?
4051 reader issue
Re: 4051 reader issue
There is a bullitan on this.
TP14 076 I edited my reply and there is no place to upload it. Shows new part number FC8-6450-010 and 4Y8-0019-000. They are new parts to the open/close sensor arm on the machine where the adf hits the arm to show the adf opened. -
Check out that posted pdf ๏ฟฝ๏ฟฝ
Also make sure
OP-SZ-DT is set to "1". ==Orgnl size dtct ON/OFF at copyboard open.
Adj/set/operate method
1) Enter the setting value, and then press OK key. 2) Turn OFF/ON the main power switch.
When set to one, all paper sizes from the platen glass will be reconized correctly.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
