IRAC2230i - E020-0060
  • Benjamin98
    • Mar 2015
    • 89
    [Error Code] IRAC2230i - E020-0060
    Hi guys,
    I have a machine with the above error code, it comes up only when printing in color. Black and white is fine. Also the error goes after the machine has been restarted.
    So far I have replaced everything as per the service manual i.e. the following:
    The yellow drum unit(not sure why it only calls for that one?)
    The registration patch sensor unit
    Primary transfer HV PCB
    Developing HV PCB
    Primary charging HV PCB
    Auxiliary HV PCB
    The mentioned fuses were all testing correctly too.
    I have updated the firmware as well to version 52.01 but still no luck!
    The machine also had a major clean-up as I noticed there was a lot of toner on the laser windows and even some inside the laser unit.
    If anyone knows what else could be the problem I'd appreciate some help.
    Ben
  • ernesto
    • Oct 2011
    • 428
    Re: IRAC2230i - E020-0060
    Originally posted by Benjamin98
    Hi guys,
    Developing HV PCB
    Auxiliary HV PCB
    Ben
    Hi,
    It could help
    All the best
    • Benjamin98
      • Mar 2015
      • 89
      So, after all this we replaced the DC controller and the error has gone but now no magenta is printed on the PG10 test?!
      I've checked all the connections as well as the laser unit itself and the magenta drum but no luck. Even went so far as to replace the laser unit but it doesn't seem like that's causing the fault.
      ???? Stuck now...
