Anyone expert in Canon IR2018, please i need some help to resolve this problem of my photocopier? Please give me step to troubleshoot..Best Solution???
Canon IR2018 System Error E261
Tags: None
Re: Canon IR2018 System Error E261
[4] : Power supply PCB
[11] : DC Controler PCBComment
First /check to make sure you are receiving proper voltage supply / & ground from your outlet__
Power Supply Unit
Removing the Main Power Supply PCB
1) Detach the rear cover (back of printer).---> 4 screws
2) Detach the right cover (lower).----> (Detach the rear cover---> Open the front cover----> Remove the two hooks (strap), and then detach the right cover (lower) __5 screws)
3) Detach the delivery tray. ----> front 2 screws
4) Remove the [Power Supply PCB [1].
- Connectors [2], 7 pcs.
- Screws [3], 6 pcs.
power supply.jpg**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
