Turn copier on,code comes on. Pls help.......:d
CAONON 5185i EROR CODE E000007-0102, PLZ HELP....
Tags: None
Re: CAONON 5185i EROR CODE E000007-0102, PLZ HELP....
gears/teeth break
pressure belt splits
this is an old tech pub on e007 checks/ attach is basically a review & check / inspection/
other pub will show how to remove unit
Disassembling and Reassembling_Fixing Unit_TP07-168.pdf
u probably have a Fixing Unit issue
not repairable in field > because parts were not cost effective anymore/ u would change one or two parts > and issue would arise following week because u missed seeing a broken gear tooth --
Twin-Belt Fixing-Unit (FM3-0691-000) is no longer available
Canon sells re-built units --800/900
new units cost cost 1,400
Complete Fixing Assembly (FM3-3778-000)Attached Files**Knowledge is time consuming, exhausting and costly for a trained Tech.**
