Hi. Have not worked on these machines in a while! I have an irc3080i that only prints and copies yellow and black. cyan and magenta completely missing.
If I stop the machine during an autograd the rear patterns on the itb (cyan and magenta) are missing.
I have swapped the two sub boards on the main controller to see if problem swapped between yellow/ black to cyan/magenta but no joy.
Is this a main controller problem or do you think 2 lasers have gone at the same time?
I have an old irc3080i at the office. Am I able to swap main controllers to test or will that kill both boards? If i can swap boards do I need to keep the sd cards with their original boards or keep them with their original machines? Any help appreciated!
