Bizhub 250/350 - C2557
  • moses smith
    Senior tec- self employed
    • Mar 2013
    • 4
    [Error Code] Bizhub 250/350 - C2557
    Clear counters changed new drum and developer, cleaned sticky sponge from 2 solenoids on hopper drive assy, ran F8 machine works fine for about 5k copies, C2557 re-appears.If i try to re run f8 the code C255C pops up. pls help!!!!
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 250/350 - C2557
    What is the machines gain set to. 145 to 155 is ok.
    Whatever
    • CraigW
      • Dec 2010
      • 417
      Did you look that the PC Life actually reset ??
      Many times it takes more then 1 attempt to get it to clear.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        when you cleaned off the sponges off the solenoids, did you replace them ?
        You cannot run solenoids without sponges they will not release otherwise once activated. C451 head cleaning pad works perfectly and is what I use in its place.
        • wseyller
          • Sep 2012
          • 1129
          EarthKmTech is correct. The sponges are there for a reason. I know this because I cleaned them off once without replacing and they will stick again from the residual magnetism.
          • allan
            RTFM!!
            • 5462
            That does happen. I have a habit of switching the machine on and off after clearing the counters leaving the door open on the restart. Its also important to get all the toner out of the drum cleaning unit before installing new developer. The B363 has a drum dry setting for this, before you change the dev its runs all the powder from the cleaning section into the old dev.
            Whatever
            • CraigW
              • Dec 2010
              • 417
              I do utilize drum dry for the machines that use it.
              Love that engine, It has been wonderful to work with. (too bad the 36/42 got those WORTHLESS !! ADFs)
              No real quirks, or surprises.
              • allan
                RTFM!!
                • 5462
                The SSD chips keep going bad on some B36/42 machines. Something todo with the fax data.
                I modify the rachet by cutting a spring with the right diameter so i have just a single coil. Put the square peg shaft into a drill chuck. Then cut a groove into it on the outer edge with a blade. Fit the spring coil into the groove. It prevents the clutch from slipping when it needs to retract the pickup roller.
                Its a poor machine. Like you said the DF really sucks. Water thens to condense inside. Look on the scanner rails on the cool stainless for water droplets.
                Whatever
                • CompyTech
                  Super Tech
                  • Feb 2011
                  • 706
                  Probably cause the scanner lamp never cuts off.. Horrible design, but engine is good.
                  • makafile
                    hi, only you change de powder developer??, you need clean the rollers inside and lubricating, sorry for my english. Because the drive motor developer have a serious force for move it.
                    • allan
                      RTFM!!
                      • 5462
                      Never lubricate a developer unit. Make sure the TD sensor gets connected. Its the connector at the back of the IU.
                      Whatever
                      • has17
                        may i get the picture...!
