DU-105 vs DU-106
  • axel
    • Sep 2011
    • 36
    [CQ] DU-105 vs DU-106
    This two drums are the same.they have the same material safety data sheet.
    Is there any one that had tried to instal in konica c1060l drum du-105?
  • andyf424
    • Jun 2013
    • 126
    Re: DU-105 vs DU-106
    I too have asked myself this same question. Curious if anyone has done it though. Kinda like the du-102's somebody had to try a du-104 to find out they work.
    • Bizhub
      • 147
      Snap the pin off and it will fit and work
      • ragnarok
        • Oct 2016
        • 2
        [ATTACH=CONFIG]31647[/ATTACH]
        Hello! Can you please post a bigger image ... can't find the bloody pin...
        • Toxic
          • 697
          Hi,
          Somebody figure out what is different between DU-105 and DU-106 and will DU-105 work on C1060L?
          • Tech Helpdesk
            • Jul 2015
            • 112
            If you look at the image closely you will see a hole at 10 'o' clock that is where the pin used to be, by removing the pin you can use the drums on C1060l no problem.
            • mariuscmr
              • Apr 2017
              • 13
              I just swapped 3 OPC drums from DU-104 to DU-106. I put OPC drum from C6500 to C3070L without any problem. They fit perfectly at half the price. And less than half of lifespan, as well. DU-104 has 180 000 clicks, while DU-106 has 460 000. But it was an emergency and I had spare parts.
