konica c250 transfer unit fuse replacement
  • DOE
    • Mar 2010
    • 258
    Will be replacing a transfer belt fuse for the first time. It is on a Konica 250. Can someone tell me where the fuse is located on the unit. Is it easy to find or do I have to take a cover off? Copier is calling for the belt to be replaced. Thanks.
  • MVPunisher
    • 209
    Re: konica c250 transfer unit fuse replacement
    I believe it is inside a plastic housing, inside the front left handle of the belt.
    When doing these I dont even take the belt out, I just slide it out about 6 inches. Remove the claw assmebly (2 screws) An e clip, spring. The plastic housing is held by a very small screw.
    10 min job or less. Cake.
    • CompyTech
      Super Tech
      • Feb 2011
      • 706
      I believe the fuse is like .80ma... very tiny... I recently was unsuccessful with one recently on a c253.(this was a new belt would not reset) Fortunately I still had a CF card and did the PPLM mod, took care of that forever. Unfortunately you can't do the PPLM mod on the C250s
      • Synaux
        • Mar 2012
        • 1224
        It is a .80ma fuse.
        Weird that it would work with the c253...next time maybe try an even smaller fuse?
        • copier tech
          • 7979
          Its the same quick blow fuse on all the C253 & C250 series machines .80mA take the long mental plate off, then look for 2 small metal contacts, the fuse is there.
          Just make sure you have a tiny Philips screwdriver & the correct fuse, too high amp fuse & it can blow the MFP board.
          Sometimes it wont blow first time, but simply power off & on the machine then wait.
          • allan
            RTFM!!
            • 5445
            They are slow blow fuses.
            Whatever
