This machine is driving me crazy. It prints fine on anything uncoated, and gloss text. But will not fuse properly on any cardstock weight gloss. Specifically #100 gloss cover is the worst. We have replaced all the imaging units, the fuser, The transfer belt, the black developer unit and roller. I have consulted locally with 2 factory techs and they have never seen anything like this before. It will print a few ok, then one or two with patches of missing toner that end up on the next sheet. and it repeats this over and over again. out of 100 sheets there will be roughly 30 bad ones. It seems like the fuser is losing heat during the run or something. Has anyone here seen anything like this?
Bizhub C654 has problems fusing toner to heavy gloss paper.
Re: Bizhub C654 has problems fusing toner to heavy gloss paper.
Hello
Has anyone come up with a solution to the problem above..
I have a Bizhub c258 which is behaving in the same way. Will print fine for 10 pages and from the 11 page will completly not fuse the image.
I have replaced the fuser unit and adjusted the fuser temperature to 10+ but we still nothing has changed. -
not every kind of paper is supported.
see attached guide for certified paper for that model.Attached FilesWe know a thing or two because we've seen a thing or two.
The medication helps though...Comment
100# gloss cover =270 GSM..Thick 4 is 250 to 300 gsm. IMHO you are trying to run a production job through a office machine, and there is no telling how the glossy coat is affecting the heating process..You said yourself, uncoated works fine, yet it's still a machine problem???Last edited by emujo2; 12-17-2021, 03:13 PM.Comment
Something similar happened to me with a bizhub c454e, the client put non-compatible toner (generic) to the machine, I had to remove the hopper unit, throw out all the toner, put the original compatible toner, take more than 500 color copies so that the toner that is in the developer change, and solve the problem
thanks
1. Service Mode - machine - Thick Paper Interval- change to image quality.
2. Service Mode - System 1 - Warmup - change to Mode 4
3. Administrator - Expert Adjustment -Image stabilization - change to colour priority.
Client needs to run stabilize through Administrator - Expert Adjustment - stabilization - atleast once a day preferably in the morning.Comment
Hi Apply the settings below:
Client needs to run stabilize through Administrator - Expert Adjustment - stabilization - atleast once a day preferably in the morning.If you'd like a serious answer to your request:
