Movie Data File Konica Minolta bizhub C224 and bizhub 363
  • ftq
    • Oct 2012
    • 8
    #16
    Re: Movie Data File Konica Minolta bizhub C224 and bizhub 363
    hi
    can anyone send me a movie data or firmware for c224? thanks
    i have all kyocera and some ricoh manual and firmware for exchange if you want
    • clip70
      #17
      Hello everyone,
      new on the forum, I'm looking for the movie data file Konica Minolta bizhub 223
      • laitang
        • Nov 2012
        • 627
        #18
        @ftq: threre 2 movie data
        Movie data v01 for firmware 53
        Movie data v03 for firmware 65 and above
        each one 1GB!
        which u want?
        • clip70
          #19
          Hi laitang
          would you have the file for konica bizhub 223
          Thank you very much
          Clip
          • johva
            • 48
            #20
            Thanks for your reply, I do have the movie data for the C224 and 363. However I just ran into a situation that I need firmware for the bizhub 222. Our copy is corrupt. please forward if available to johva@ameritech.net. Thank you, johva.
            • Synthohol
              Certified Konica Expert
              • 5824
              #21
              Release Notes: 222, 282, 362 MSC Phase 2.0 Firmware Version 08
              CAUTION: You CANNOT upgrade Phase 1.0 machines to Phase 2.0 level firmware Phase 2 serial number cut in: From "A11W011002051" onward => bizhub 222 Phase2 From "A11V011001338" onward => bizhub 282 Phase2 From "A11U011001706" onward => bizhub 362 Phase2 Serial numbers below are Phase 1 systems. SEE DLBT0902293EN00.pdf for a list of enhancements
              Release Notes: 222, 282, 362 MSC Phase 2.0 Firmware Version 06
              CAUTION: You CANNOT upgrade Phase 1.0 machines to Phase 2.0 level firmware Phase 2 serial number cut in: From "A11W011002051" onward => bizhub 222 Phase2 From "A11V011001338" onward => bizhub 282 Phase2 From "A11U011001706" onward => bizhub 362 Phase2 Serial numbers below are Phase 1 systems. SEE DLBT0901286EN00.pdf for a list of enhancements
              Release Notes: bizhub 222, 282, 362 MSC Firmware PHASE 1 Version 00
              be careful which firmware you try and use!!!
              that whole series sucked for firmware.
              lemme know if you need the actual bulletins.
              • johva
                • 48
                #22
                Synthohol :
                I'm not sure my problem is with the firmware. bizhub 222. The Simplex/Duplex application screen, Original reads single sided - double sided, Copy reads single sided, double sided is MISSING. Any thoughts, please let me know. Thank you, johva.
                • copier tech
                  • 8144
                  #23
                  Synthohol :
                  [ATTACH=CONFIG]37756[/ATTACH]
                  Start a new thread & include the model number.
                    • 14725
                    #24
                    Synthohol :
                    This symptom is usually caused by a DF problem
                    • mihailelea
                      • Jan 2018
                      • 44
                      #25
                      Hello
                      I have bought a KM Bizhub C364 second hand and I think the HDD was formated.
                      I have the following error messages:
                      "OCR Dictionary not found. Contact your Service Representative";
                      "No Animation Guide available. Contact your service rep." and
                      "Please turn on the Modem Unit"
                      If someone could please send me the software to install I would be very grateful
                      I think after watching 3 days of tutorials and searching the web I know how to install, but I need the software.
                      Thank you!
                      my e-mail: mihailelea@yahoo.com
                      • PinkPanther
                        • Dec 2016
                        • 13
                        #26
                        hello,
                        i have the same problem here with my c224 (the replacemant for my c203)
                        The former owner did for security, and to clean user adjustments, a HDD format.
                        So far so good, but as you now, the movie file is lost after.
                        Does somebody of you have the Movie file for the c224?
                        I have service documentation, but I do not have the movie-file
                        Thank you in advance.
                        • copier tech
                          • 8144
                          #27
                          • Rylac
                            • Feb 2015
                            • 26
                            #28
                            Would anyone be able.to help me out with a C284 movie files?
                            Seems they are different than the c364 movie files.
                            Thanks in advance
                            • PinkPanther
                              • Dec 2016
                              • 13
                              #29
                              Hi Rylac,
                              check your inbox. :-)
                              • pannoniapeter
                                #30
                                Hi!
                                New to this forum, glad I found it thoug!
                                Recently bought a secondhand C224, and it does complain about the Animation
                                Could somebody send me the Movie Data File, please?
                                Thanks in advance!
                                Peter
                                ROM versions:
                                MFP Card Version A1610Y0-F000-GF4-72-970
                                MFP Controller BOOT Program A2X00Y0-1E00-G00-01(00)
                                MFP Controller Linux Base Linux-2.6.26.8-rt16
                                MFP Controller Kernel Program A2XK0Y0-1C00-GC2-19
                                MFP Controller SubSet A2XK0Y0-1F00-G00-08(00)
                                MFP Controller A2XK0Y0-0100-GF4-72(00)
                                Operation Panel Message Data A2XK0Y0-8100-GCZ-72-970
                                Fax Board Controller1 A22M0Y0-4000-GCA-11(00)
                                Fax Board Controller2
                                Scanner A2XK0Y0-0023-G00-11
                                Printer A1610Y0-0050-GD1-32
                                ADF A3CF0Y0-0024-G00-16
                                Finisher
                                RU
                                ZU
                                Panel CPU A1610Y0-8900-G61-00
                                DSC1
                                DSC2
                                Loadable Device Driver1
                                Loadable Device Driver2
                                SD
                                Voice Data
                                Movie Data
                                Dictionary Data
                                OCR Library
                                MFP Controller System A2XK0Y0-1000-GF4-72(00)
                                MFP Controller Print Controller A2XK0Y0-3000-G00-BR
                                MFP Controller Print Controller Font A2XK0Y0-3F00-G00-2B
                                MFP Controller Print Controller Demo Page A2XK0Y0-3E00-G00-01
                                MFP Controller MIO A2XK0Y0-5000-G01-X1(00)
                                MFP Controller PIC A2XK0Y0-8200-GC2-13
