Konica C368 Error code 9401
  • bigdcopy
    • Dec 2010
    • 70
    [Error Code] Konica C368 Error code 9401
    I have an almost new C368 with error code 9401. The scan lamp does not come on our tech support said it was the CCD I replaced it and updated the firmware no change. I think it is either the scan lamp(LED) or the scan drive board. Any ideas am I on the right track?
  • habik
    • 2013
    Re: Konica C368 Error code 9401
    I guess you are. Check the voltage on the board.
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
      • 23008
      Agreed. It shouldn't be hard to read the DC voltage to the LED array. Just raising the lid should light the LEDs.
      So you told tech support that the lamp was not lighting, and they still recommended the CCD? Genius. =^..^=
      • copyrooks
        • Oct 2013
        • 209
        Last time I had this code on another machine I ended up replacing the scanner drive board, CCD assy, and mfpb. The mfpb fixed it
        • bigdcopy
          • Dec 2010
          • 70
          Scan Lamp and scan drive board fixed issue
