Does the C253 transfer belt use a fuse to reset the counter? If it does what size is it and where is it located on belt. Thanks.
Konica Monolta C253 Transfer Belt
Re: Konica Monolta C253 Transfer Belt
Yes it uses the same fuse as previous models 800mA
It is under a small black cover on the end just look for the two small contacts, undo one tiny black screw.Let us eat, drink, and be merry, because tomorrow we may die!
most pico fuses are .068 or 1/16th of an amp.
thats all ive ever used even since the analogs.We know a thing or two because we've seen a thing or two.
The medication helps though...Comment
