Strange problem here, machine had a c5102 code, I replaced main drive motor, no problem, code is taken care of, I ran a couple of test pages, everything is fine, turn the machine of so I can unplug it and move it back into the cuby hole it sits in, plug it in, turn on, goes through the warm up, and then stabilizing image as these machines do, when the motor stops running, it does not come ready, just says stabilizing image and will not come ready, the motors are not running at all, only one of the fans.
Any ideas???
Any ideas???
