Bh601 paper size issue
  • Synaux
    • Mar 2012
    • 1224
    12x18 in tray 3,4 and bypass is always recognized as A3.
    When I put anything in bypass, the only standard paper sizes are A or B sizes we want standard inch sizes.
    Marketing has been set to US. I cannot seem to find any other settings for this. There is "tray"calibration in Service Mode but not available for bypass.
    Someone please point out the obvious that I am missing...
  • allan
    RTFM!!
    • 5462
    Re: Bh601 paper size issue
    System 1 -> Detection size setting?
    Whatever
    • Synaux
      • Mar 2012
      • 1224
      Thanks, but I tried that... everything is set to B Series.
      *edit* I just switched it to K series (whatever that is) and back to B. I had to switch to B Series three times to make it stick; however, suddenly auto-detect started working--which is good enough.
      Standard Sizes still show:
      And 12x18 is still showing as A3, but the main issue is cured
      (I need to start bringing my voodoo stick with me at all times)
      • allan
        RTFM!!
        • 5462
        Weird. The other day i had a C452 that change only tray 3 to inch all the other trays was set to metric.
        Puzzled me for a while when in doubt do a system error clear and it was fixed again.
        The table 1 table 2 setting for the original length detection also needs to be toggled if the machine only detects A3 from the platen.
        But why??
        Whatever
