BizHub 250 faxing
  • copyman
    Owner / Technician
    • Sep 2005
    • 4701
    BizHub 250 faxing
    I still have a few customers that wont let go of these. Can't say I blame them since this model is such a good workhorse. I upgraded most of them but still have a few I service. Most would probably still have them if not for the faxing issues.
    Customer says they can RX fine but TX is giving them trouble. They claim it is only certain #'s that wont go through. Of course they verified the destination #'s by sending from a stand-alone fax and they TX fine.
    I remember a lot of issues with VoIP and the older K/M models. I think this was one of the issues? But I remember a Biz 250 that wouldn't TX at all and just ring. The customer says some faxes go through.
    Anyway it's been awhile since anything came up about this and wondering if anyone ever found a workaround to get a biz 250 (FK-503) to work with VoIP?
    Thanks in advance
  • Woxner
    • Jul 2011
    • 848
    Re: BizHub 250 faxing
    no support for voip.
    • Flash
      • 378
      you can try lowering the baud rate to 14.4kb or 9600 if that is an option.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4701
        Thanks wox, that's what I figured. Now that I think about it you may have told me this same thing way back on Smarka
        Older models Faxes were designed for copper lines. VoIP was not that common when this model was out.
        • HuronMan
          • Jul 2009
          • 68
          The biggest help on a VOIP system is to turn off ECM. Go to tech mode, soft sw. 041, bit 6 and make it a zero. You can see if that helps. If not try setting sw's. 048 to hex c6
          049 to hex 05
          050 to hex 05
          • copyman
            Owner / Technician
            • Sep 2005
            • 4701
            Thanks Flash & Huronman, will give it a try.
