Fiery Pro80 v3.0a update error
  • joaodaffonsojr
    • Aug 2014
    • 53
    hi !
    I'm trying to install fiery updates but this error is not let me do it.
    any ideas ?
    thanks !
  • Albonline
    • Sep 2008
    • 1151
    Re: Fiery Pro80 v3.0a update error
    Originally posted by joaodaffonsojr
    hi !
    any ideas ?
    thanks !
    [ATTACH=CONFIG]34098[/ATTACH][ATTACH=CONFIG]34097[/ATTACH]
    updates are version specific, are you tring to cross platforms?
    • joaodaffonsojr
      • Aug 2014
      • 53
      No.
      This is a webremote for my KM c6500.
      • Albonline
        • Sep 2008
        • 1151
        you misunderstand 3.0 and 3.0a are different. if you loaded 3.0 the 3.0a patches will not work.
        • joaodaffonsojr
          • Aug 2014
          • 53
          ok
          I understood that they are different.
          Problem is that it doesn't load ANY patches.
          Problem is to find updates.
          Fiery try to connect to look for patches but gives this error.
          • redhotrob
            • 69
            Try using the updater that is done in the web browser, and use Internet Explorer. EFI mentioned something in the latest Tech Ticker about updates for those older controllers not working, and I think the recommendation is to use ie.
            • Synthohol
              Certified Konica Expert
              • 5836
              what is the error code, the pics are so small and unreadable.
              can you get on the internet? are the dns and gateway settings correct?
              • joaodaffonsojr
                • Aug 2014
                • 53
                Screen Shot 2016-09-14 at 4.04.49 PM.jpgScreen Shot 2016-09-14 at 4.05.12 PM.jpg
                here goes another screen print.
                ip address and dns
                • jotunn
                  • 617
                  First of all, for successful update you need properly set Time Zone, current date and time - those controllers are little bit old and usually got weak mainboard batteries, so I'm using additional tool for automatic time setting: NetTime
                  The second thing is, that controllers after software reinstallation have outdated SSL certificates, so they cannot connect with update servers (Error 10) to update those certificates - so you need to get and manually install patch FIT101063085.exe that contain current certificates.
                  Log into your controller through remote desktop, from the controller go to website:
                  http://liveupdate.efi.com/WebUpdater/default.aspx?uv=004&sid=bad4942515853714db4cda2dce 48491eEF778075.PPD - find, downlad and install above patch. Then reboot your controller, and try to run update, now should work.
                  • Synthohol
                    • 5836
                    ftp.efi.com
                    if prompted:
                    user name: customer
                    password: cu$Tom3r
                    find FIT101063085
                    enjoy and good luck!
                    • jotunn
                      • 617
                      ftp.efi.com
                      if prompted:
                      user name: customer
                      password: cu$Tom3r
                      find FIT101063085
                      For me it never worked, I can see only directory structure, can enter any of them, but there are no files inside (from my point of view).
                      • Synthohol
                        • 5836
                        x; "> </Problem
                        Solution
                        CAUSE: SSL Certificate has expired.
                        Problem Solution
                        Related Products:IC-303,IC-305,IC-408
                        Related Options:
                        Detail Detail
                        1 of 2 9/16/2016 11:37 AM
                        SOLUTION: Install attached patch 1-1CO771.
                        1. Install this patch locally.
                        3. The install takes approximately 1 second.
                        5. Reboot controller.
                        Notes:
                        a. Use this patch if you get this problem only.
                        • jotunn
                          • 617
                          • methogod
                            • Dec 2008
                            • 921
                            Had a clean install of 3.0A installed this patch, still getting error 10.
                            thanks,
                            • Synthohol
                              • 5836
                              which patch? the one i posted from konica or the FIT patch from EFI?
