C280 with error code C 2560
  • fearless
    • Jun 2015
    • 20
    [Error Code] C280 with error code C 2560
    Hello to all
    Has any body dealt with error code c 2560 on konicaminolta c280? what was the fix if you remember?
    thanks a lot
    Happy Thanks giving to all
    • 22936
    Re: C280 with error code C 2560
    Could it be C2561, C2562, C2563, or C2564? Printcopy does not show this as one of the possible codes. =^..^=
    • fearless
      • Jun 2015
      • 20
      it has to do with SV ERB OR PRCB-PWB .
      • Woxner
        • Jul 2011
        • 829
        if it turns out to be code from last post its a tcr error ( toner control) being dev ratio is off. may need to check tone add or try adding toner through toner add mode. anyhow all these codes are in the service on the machine. tells you what the error is.
