faint coloured
  • insigniawales
    replied
    Re: faint coloured
    Could be the media type. If the weight of the paper is greater thatn 80gsm it could cause banding as described. You can adjust the 2nd transfer voltages in service mode
    Sent from my SM-G903F using Tapatalk
  • M3HR4N
    replied
    Re: faint coloured
    I've got the same problem, change anything you name it but no luck.
    replied
    Re: faint coloured
    I can wait for the details. =^..^=
    replied
    Re: faint coloured
    If it is on all colours, I would suspect the transfer belt or roller. Also, use the magic wand on the inside of the door to clean the printheads.
  • myster
    replied
    Re: faint coloured
    It may be dirt in the optics of the laser, it has to be disassembled and cleaned well
  • Synthohol
    replied
    Re: faint coloured
    the stripe, is it in the feed or cross direction was the question.
  • spidar
    replied
    Re: faint coloured
    Is you faint area in which direction on which size paper? =^..^=
    A4 & bigger than A4
  • Synthohol
    replied
    Re: faint coloured
    good question!
    i just assumed it was the trailing edge from memory of that image.
    replied
    Re: faint coloured
  • Synthohol
    replied
    Re: faint coloured
    there is a setting for adjusting transfer voltage of trail edge.
  • spidar
    started a topic faint coloured
    faint coloured
    Konica Minolta c452
    I have this faint band in 4 colours test.
