C6000 Lower Fuser Temp Fault C-3912
  • CopierCare
    • Aug 2015
    • 24
    OK I really need some help here. I am desperate. I have a C6000 that get a C-3509 fault then after reset warms up forever then gets a C-3912. Upon inspection the lower fuser roll never heats up. I have replaced lamp, thermostat, thermistor or temp sensor both front and rear connector on fuser section / Frame, the AC Driver board and Printer control PWB. I can measure voltage all the way to the board but still no heating up on the lower fuser roll. Ideas ? Help!
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5824
    Re: C6000 Lower Fuser Temp Fault C-3912
    You are replacing lamp L5 right? Single lamp in lower roller? A03um32*00?
    The star is for a e or f depending on your country. E for USA
    • CopierCare
      • Aug 2015
      • 24
      Yes replaced with correct lamp
      • Synthohol
        • Mar 2016
        • 5824
        Have you tried an ohm meter at the connector to make sure the lamp circuit is closed?
        • CopierCare
          • Aug 2015
          • 24
          Yes. I am sure the lamp is good. also checked circuit all the way from and back to AC Driver Board.
          • Synthohol
            • Mar 2016
            • 5824
            Error
            C-3912
            Root Cause
            C-3912 code at power up or "Machine warming up please wait" message.
            Workaround/Fix
            PROBABLE CAUSES:
            1. Failed ACDB.
            Replace the ACDB (p/n A03U H520 02).
            Note: Before replacing the ACDB ensure that temperature sensor/3 (TH3) is working. TH3 will read if one of the fuser lamps is open.
            2. Failed fuser lamp(s).
            Check continuity of the three upper fuser lamps L2, L3 and L4. Check the operation of the three upper fuser lamps in the Service Mode by following the steps below. Replace failed fuser lamp (p/n A03U M31E 12 for bizhub PRO C5500/C5501/C6500/C6500P/C6501/C6501P/C65hc and p/n A1DU M31E 00 for bizhub PRESS C6000/C7000/C7000P/C70hc/bizhub PRO C6000L).
            a. Press Utility/Counter.
            b. Press "Stop 00" "Stop 01" to access Service Mode.
            c. Press State Confirmation.
            d. Press I/O Check Mode.
            e. Enter code 45 using the numeric keys.
            f. Press Access to enter multi mode 11 (L2).
            g. Press the START key. Verify the lamp comes ON.
            h. Press the STOP key.
            i. Press "C" key to enter another multi mode.
            j. Repeat steps 6 through 8 for multi mode 12 (L3) and 14 (L5).
            • CopierCare
              • Aug 2015
              • 24
              Thanks for the help. Even though it was pointing to the lower lamp L5 it was an upper lamp L2 not lighting. Ordered lamp and will let you know.
              • CopierCare
                • Aug 2015
                • 24
                Upper lamp fixed it! Thanks for the help
