Hey guys:
I bought a FK502 (USED with wrong mount kits) for a later model machine, and a mount kit (new for biz 361) from another seller. When I installed the FK-502 per the bizhub 361 install instructions, everything looked/worked great, EXCEPT: can't store a fax into memory to TX, it reads 'job canceled due to insufficient memory' . I don't have a problem printing or copying photos (with or without FK installed), but get this error on a single page with a 3" face drawn with a black pen on the page and an arrow pointing to each edge. In case I'm not clear, the machine is a Biz 361 BLACK machine. Because black is beautiful!
I can't afford to blow my machine up or fight with a broken/misconfigured FK board, so I've ordered another 502 from my actual model machine (was not available at the time). If I have this problem with the 'new' used kit I'm ordering, could it be a softswitch setting or problem with my machine? On the 361, it doesn't use the PCI riser, it plugs directly into the connector using the MK.
The only strange symptom my machine has, is if I leave it unplugged for a long time, it loses time/date. Am I correct that there is no Li-ion or other battery, but a 'capacitor battery'? Could not find any reference to the word 'battery' in entire SM or Parts man.
