C554 skewing
  • copycart
    • May 2009
    • 97
    [CQ] C554 skewing
    Copier is skewing when making copies from the Document feeder and glass, but internal prints are not skewed
  • Azharuddin
    • Jun 2016
    • 33
    Re: C554 skewing
    Just adjust the ADF on the right side hinge . There will be a adjustable screws .
    Sent from my XT1562 using Tapatalk
    • copycart
      • May 2009
      • 97
      Re: C554 skewing
      I can see that if it was an ADF skew only but if I lay it on the glass I also get skew from all paper trays
        • 23008
        Re: C554 skewing
        Most likely the scanner frame had been bent by leaning on the corner. =^..^=
        • rrrohan
          • Sep 2011
          • 1977
          Re: C554 skewing
          Grab the front left corner of scanner and give it a few upward jerks. Otherwise adj scanner position wgere it sits on wire. Youll only want to move it like 1mm or so.
          I try to see if it swuare by lining it up to a straight edge on the frame.
          I find its normaly when there is a shelf above copier. They lean on copier of rest boxes on adf but have had a few at runup too so yeah
          • copycart
            • May 2009
            • 97
            Re: C554 skewing
            Pulling up on the scanner did the trick, Thanks
