C284e error C2253 after being transported to a new location
Re: C284e error C2253 after being transported to a new location
Dude if it has evidence of a rear impact you could be looking at a hairline crack on any board.
Looking at your picture it looks like a fairly hard impact.
Send it back to base/swap it out even if you fix that issue it could cause many headaches in the future!Let us eat, drink, and be merry, because tomorrow we may die!
โComment
maksima
Thanks, most likely this is what I'll end up doing. Doesn't look like an easy fix.To bad this is a beast of a MFP.
They usually move ok without damage. I've had them shipped to me from hundreds of miles away and 99% of the time they are ok. And that's saying a lot if you saw some of the trucks & drivers!Comment
maksima
It depends if it is moved properly crated on a pallet vs ghetto style strapped inside a minivan. We got it ghetto style. With all the cartridges, drums, etc installed inside the printer. What are people thinking?Anyone with a service manual could share how to get to M2 motor?
All the machine I get always have the toners, dev units and drums left inside when shipped. I would rather have the consumables left in machine when transported. Better than being removed and drums exposed to light & dirt, Dev & toners mixed up between machines, etc.
As long as machines aren't tipped over drums, toner, devs are fine left in machine.Comment
Here the CE manual but i'm not sure it will help!
https://mega.nz/#!sAkXwKLZ!k-SWcEjzFeMFbAdq9wC4KzYjwQzByIxI-ymqYOuSzOQ
โComment
maksima
We recently had one shipped to us from another dealer and it was shipped laid down on the right hand door side of the machine, on a pallet. Apart from one broken panel and scratches on every other panel, it worked okay.Comment
I would remove the drum, developing unit and transfer belt and try turning them by hand. it's rare that a motor actually goes, it's usually a consumable that bound up because all the developer is towards the back or towards the front of the DV unit
good luckWe know a thing or two because we've seen a thing or two.
The medication helps though...Comment
