Bizhub 353P Sandglass
  • ArtPetrovich
    • Jul 2025
    After trying setting the parameters to use SimWin:
    Turn on the printer
    2. Press Menu/select key
    4. Press Menu/Select key
    5. Insert the password (92729272) and press the Menu/Select key.
    the cancel key.
    11. Turn off the printer
    Upon further turning the printer on on the screen appears an hourglass.
    When trying to do a Trouble reset (when switching on hold the Central button) on the screen above right appears a black point.
    As I understand it, I need to sew the NVRAM? There is Compact Flash 256mb, but I have not the firmware and the instructions for the firmware.
    Please help in the restoration of the machine, thanks in advance.
