Bizhub C280 - copy / print jammed ONLY in color mode
  • cristachecri
    • Mar 2015
    • 31
    Hello everyone .
    I have a Bizhub c280 machine and has a problem: just in COLOR copy / print mode the paper jams. Specifically as in BLACK copy / print mode everything is fine. It is a frustrating flaw and I can not find the solution. Why is this problem only in COLOR mode ? I'm waiting for your answer or a repair method with great interest . Thank you
  • Tech Helpdesk
    • Jul 2015
    • 112
    Re: Bizhub C280 - copy / print jammed ONLY in color mode
    Originally posted by cristachecri
    Hello everyone .
    Had this problem years ago when putting crap toner in a C250 and it would jam in the fuser area. If you are using compatible toner then check the fuser unit and if it looks dry or dirty change to original toner and gradually run halftone test prints in service mode to deplete any cheap toner on all colours. When the original toner starts getting into the system the prints will look glossier and the jamming will eventually stop.
    The reason it jams on full colour mode is down the amount of toner that is on the page and if there is no wax present in the toner (as with compatibles) it will be like glue in the fuser hence the jamming in full colour mode.
    • cristachecri
      • Mar 2015
      • 31
      Thank you for your prompt answer . Solving this malfunction is far away. Toners are just original, the cylinders are the same and the paper jams are just after they exit the tray and only when they are copying / printing color. I mention that the device has only 40,000 copies of which only 10,000 color.
        • 22997
        Jam codes? =^..^=
        • copyman
          Owner / Technician
          • Sep 2005
          • 4620
          Something doesn't add up. are you sure when using color it doesn't pull from a certain tray. Or manual feed tray with thicker paper, etc.
          Is the paper size correct for each drawer, man feed tray?
          Does it jam when using side manual feed tray?
          As far as feeding paper the machine doesn't know or care if you are printing color or B&W it just feeds paper. My guess is one of your paper inputs has small piece of paper jammed or just needs rollers replaced.
          • cristachecri
            • Mar 2015
            • 31
            I will try to be as explicit as possible. The copier works absolutely normal,
            copies and prints from all trays, including bypass only in black. As soon as you switch to Color Copy / Print mode
            the machine locks the paper as it exits the tray. I tried all the trays and every one of them happened the same. Device
            does not display any code when it blocks the paper. If the copier is only in black mode, the machine is perfect.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4620
              I will be explicit as I can.
              Sorry still doesn't make sense. Color or B&W shouldn't matter with a paper jam. If you are saying paper will exit then indicate a jam that is usually the exit switch near fuser (not sure why only color). Or different paper size is fed other then what shows on display.
              Like blackcat posted, what is the jam code?
              • Tech Helpdesk
                • Jul 2015
                • 112
                Try doing halftone prints from service mode and see if it jams. I still suspect the full toner coverage as it is jamming at the fuser. Are you sure that everything in the machine is original ?
                • allan
                  RTFM!!
                  • 5462
                  Look in the history for error codes and the jam codes.
                  It could be that its a processing problem, but that would normally give an internal error message where you need to restart.
                  If that is the case the half-tone should print fine. Even try a demo page.
                  Does color scans work?
                  Whatever
                  • AjitN
                    • Mar 2009
                    • 287
                    Only difference that I can think of is for B&W copy Only black drum rotates and also 1st Transfer rollers are not in contact with drum. I do not know if this is loading some motor OR Gear Assy, Clutch OR Solenoid which is affecting paper feeding in case of colour copies.
                    If paper is leaving tray feed area and not reaching Fuser, that means it is somewhere at registration assy. OR Belt/2nd transfer assy.
                    Need to check thoroughly
                    Hope this helps.
                      • 14505
                      cristachecri It has been suggested several times for you to post the jam codes. They will help in further troubleshooting of the jamming problem.
                      So, please post the jam codes.
                        • 22997
                        If you don't know what jam codes are it would be a good idea to hire someone who does. =^..^=
                        • joelea
                          • Feb 2012
                          • 64
                          Hello everyone .
                          I've had a few weird issues on this model and sometimes to fix it I would initialize all data in service mode, its worth a try just make sure you have movie data to load back on and don't forget to enable the HDD after you've done it as well.
