Hi hub 600
  • tcypy1961
    • 773
    Hi hub 600
    Was called out forC3803. After resetting a misdeed message comes up. Have pulled fuser and can't find any reason for misdeed message. Was told a misdeed occurred when running letter LEF. Misdeed was removed and supposedly reset. Not sure when the C3803 came up. So which of the two thermistors is the problem??? I've been told #1. Is #1 the middle or end??? I'm not only unfamiliar with this machine I also have no manual other than the Intravia guide. What is most likely causing the misdeed error???
    Thanks!!!
  • copyman
    Owner / Technician
    • Sep 2005
    • 4701
    Re: Hi hub 600
    I see your hitting the bottle again! I told you to lay off the juice!! Every time you drink you act like an idiot !!!
    You drinking is a MISDEED......
    Now go sleep it off !!!!
      • 14728
      Re: Hi hub 600
      First: punish the machine for its misdeeds.
      Second: TH1 is, I think, the centre thermistor. It may just be somehow insulated from the fuser roller by toner or a small piece of paper. Check it first.
      Otherwise, you may need to replace it.
      • tcypy1961
        • 773
        Re: Biz hub 600
        Thanks!!!
        How do I reset a misdeed error that has no apparent cause(no paper/obstruction & the only 2 switches I can see are mechanically ok???
        Thanks!!!
        • Synthohol
          Certified Konica Expert
          • 5824
          Re: Hi hub 600
          Cxxx=trouble code
          Jxxxx=jam code
          NOTE
          • C-3401 to C-3901 (fus
          ing temperature related
          abnormalities) occur,
          be sure to repair defec
          tive parts before set
          ting the software
          DipSW3-1 to 0.
          • Setting the DipSW3-1
          to 0 with
          defective
          parts not repaired may
          result in a fire.
          • tcypy1961
            • 773
            Re: Hi hub 600
            The request should have been mis-feed not misdeed. Thanks!!!
