Can't get scan to print to work with gmail business bizhub C284
  • printerpurgatory
    • Jan 2018
    • 23
    [Misc] Can't get scan to print to work with gmail business bizhub C284
    Hello, newbie here. I can't get the scan to email to work. We're using gmail business so I've tried with and without authentication and neither worked. I actually already made a post about this in Network Connectivity but it seems that it was deleted or something. I have everything setup to not use authentication ATM and have setup the gmail account to use "less secure apps". Any help would appreciated. I've also made sure to set the device email and admin email to the same address and have made sure that ssl and tls are enabled.
    E-mail TX Setting
    Scan to E-mail ON OFF
    E-mail Notification ON OFF
    Total Counter Notification ON OFF
    SMTP Server Address Please check to enter host name.
    Use SSL/TLS OFF SMTP over SSL Start TLS
    Port Number (1-65535)
    Port No.(SSL) (1-65535)
    Certificate Verification Level Settings
    Validity Period Confirm Do Not Confirm
    CN Confirm Do Not Confirm
    Key Usage Confirm Do Not Confirm
    Chain Confirm Do Not Confirm
    Expiration Date Confirmation Confirm Do Not Confirm
    Connection Timeout 30 60 90 120 150 180 210 240 270 300sec.
    Max Mail Size Limit No Limit
    Server Capacity Mbyte(1-100)
    Admin. E-mail Address
    Device Mail Address
    Authentication Setting
    POP before SMTP ON OFF
    POP before SMTP Time sec. (0-60)
    SMTP Authentication
    SMTP Authentication Method
    Kerberos ON OFF
    NTLMv1 ON OFF
    Digest-MD5 ON OFF
    CRAM-MD5 ON OFF
    LOGIN ON OFF
    PLAIN ON OFF
    User ID
    Password is changed. (Password is currently set.)
    Password
    Domain Name
    Binary Division
    E-mail TX Setting
    Admin. E-mail Address printer@domain.com
    Device Mail Address printer@domain.com
    SMTP Authentication
    Kerberos ON OFF
    NTLMv1 ON OFF
    Digest-MD5 ON OFF
    CRAM-MD5 ON OFF
    LOGIN ON OFF
    PLAIN ON OFF
    User ID printer@domain
    Password
    Domain Name
    Binary Division
