Bizhub 950
  • antone
    • Oct 2014
    • 344
    Bizhub 950
    All trays all sizes...when feeding the short edge direction.......the First 3 to 4 inches is wavy coming out. LONG EDGE IS FINE
    Sent from my SM-N950U using Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5745
    Re: Bizhub 950
    If you remove the finisher does it still warp the paper on exit if so probably during the turnover after it leaves the fuser if it's straight have an issue in the finisher.
    Could also be a short grain vs long grain paper issue and humidity.
    Make sure the rollers under the adu are super clean of all dirt and toner.
    You can also try printing face up to eliminate the turnover area as the cause.
    • antone
      • Oct 2014
      • 344
      Re: Bizhub 950
      I did remove finisher..
      Same thang!
        • 22954
        Re: Bizhub 950
        Did you look at the curl adjust? =^..^=
        • Synthohol
          • 5745
          Re: Bizhub 950
          try face-up copies (in finishing choose face-up)
          this eliminates the turnover process and comes straight out.
          if waves are still there check the exit roller one way gear. it may be slipping a bit and as the fuser is pushing it out if the exit roller is slow that may be where the collision starts and causing wavey paper.
