Dirty print (vertical magenta and cyan lines - about 225mm long) KM BizHub PRO C6500e
  • bula02
    • Oct 2017
    • 2
    Hi,
    I have a problem with my KM C6500, since last week i have a vertical magenta and cyan lines for about 225mm long. After dirty lines the print is clean for about 400mm and after this it's dirty again (clean->dirty->clean->dirty->clean...).
    Do you have anu idea whats wrong?
    https://wdruk.pl/wp-content/uploads/2018/11/IMG_20181122_202656_min.jpg
    Krystian
  • Toxic
    • 696
    Re: Dirty print (vertical magenta and cyan lines - about 225mm long) KM BizHub PRO C6
    Try to print test pages from service mode (test patern output mode,patern 53,density 125) ,one by one color only and check is dirt on every color or not.
    Is it every time same lenght of dirt, 225mm?
      • 22968
      225mm is a drum, probably magenta, but you'll be able to tell by looking. =^..^=
