Re: Bizhub C558 Account track, maximum allowance
You can on the new range of bizhubs, but not the earlier range.
User Authentication on MFP is the Auth Method with y soft card readers and cards
Yes the jobs were in the list still but you could not print them.
We have sorted the issue now with changing WHEN # OF JOBS REACH MAXIMUM Setting to Stop Job rather than Skip or delete.
Customer can now log in through web browser and either reset the limit or increase the user's allowance.
Thanks for all your help guys.Leave a comment:
Do you use account track as the authentication metod?
Are the jobs visible in the LK-114 job list even after the limit is reached?Leave a comment:
You can't log into the machine as administrator while a job is in the printer's queue anyway, so it wouldn't matter if there was a way to prevent deleting the job after maximum allowance has been met.Leave a comment:
There's an option in the setup to stop printing when job limit is reached, not sure if that would hold or delete further jobs/printing? I think the default is delete but don't have a machine to hand to confirm this.
Could you default the print queue to 'Secure print'? That way the user would be in front of the copier when the limit is reached and the jobs would be held in the queue? You can put a shortcut to Secure Print on the Home screen to make access quicker.
do you know where the option is for stop printing when job limit is reached?Leave a comment:
Could you default the print queue to 'Secure print'? That way the user would be in front of the copier when the limit is reached and the jobs would be held in the queue? You can put a shortcut to Secure Print on the Home screen to make access quicker.Leave a comment:
